Lighturn and RDworks
I have a question. I was cutting 1/4 birch ply. I was using a Boss LS3655 100 watt laser. I first cut the ply using RDworks with the setting of 65 power and 10 speed. It cut through like butter. I then used the same setting in Lightburn and it did not cut all the way through. Is there that much difference in the same settings between Lightburn and RDworks? Or is there a setting somewhere I have not found.
You most likely didn’t use the same setting - A very common mistake is ignoring the “min power” value. In RDWorks you’ve likely set it the same as the “max power” value, but in LightBurn you’ve probably left it alone.
Read here:
