Hej I opdate til version 1.5.01 og now the programme can not start. It commes out wiht the following fail: VCRUNTIME140_1.DDLcan not be found… Can you help…?
Check here:
thanks for help…I am happy now…
I downloaded version 1.5.01 and installed no problem. I downloaded 1.5.01 and windows see it as a threat and ask if I want to keep it. I have but when I try to install it’s now wanting to install microsoft visual C++2015-2022. Is they a problem with this patch release?
Thank you I had the same issue after updating lightburn. The program would not install. After installing from your link things seem to be working as should.
Many Thanks
This is “normal”? I’ve never seen it before… Should it be installed first and then updated to version 1.5.01?
This is not very elegant guys.
It was added to address a C++ runtime dependency issue that some people were getting. Close out if you’re not interested in installing it.
