The laser is going to the home position when the job is completed. This is a new occurance as it typically stops where the program ends. When it arrives home, it triggers the limit switch. Is there anything I can do, a setting maybe, to stop this from happening? I have Xtool D1 pro 20 watt. Thank You
I replied in your other Topic. It seems you’re either working in the wrong device profile or somehow your profile was recreated.
You can change the end position of the job by changing the value of “Return to finish position” in Edit->Device Settings.
