I just installed Lightburn on my Shapeoko with a J-tech laser and am just trying to get started. My machine will only jog a few inches from the corner. It will go about a foot down and to the left, and it seems to try to go farther back and right than it is capable of going. Maybe it thinks it is starting from the bottom left corner? Right now it is in the top right.
Suggest you review the LightBurn documentation on common GRBL setups including the Shapeoko.
Common GRBL/GCode Setups - LightBurn Software Documentation
You’re likely in negative workspace which is what’s causing what you’re seeing.
