I have just updated to 1.5 new to 1.5… and updated 1.5.02
If I say one pass it does 2, if I say 2 it does 4, 3 does 6… etc
I think what I am seeing is a cleanup pass after each main cut however for the life of me I cant fine where to turn it off ( or on for that matter)… ?
Does this have to be done with $ code ? if so what is the code number please.
Its probably very simple but I cant see it… must be getting old.
Many thanks in advance.
Machine is Xtool D1 Pro 20watt… working fine in other respects
Thanks for the reply…
Good point …
There is no design as such here, just a number of squares so I could test cut some acrylic to find the best settings…(different speeds / power).
However I think I must have used the duplicate command to make the next square and so on.
I can confirm that the squares did indeed have two squares sitting on top of each other. … My bad… thank you.
However where do I find that “Cleanup pass” setting please, referred to in 1.5?
