Is line interval the same as focus spot ?
Line interval controls the spacing between the lines. Larger spacing the scan lines become more visible as they are further apart… this indirectly controls lines/inch.
Draw a small square in Lightburn and select ‘fill’. You can change the line interval here and see the results on your laser … and in ‘preview’…
Thank you very much.
