Why? Line nodes won’t connect to other nodes? What is the trick? And why did the nodes on a new line turn all red?
I fight this same battle. Zoom way in and you will see why. It also helps if you make the node markers larger.
Connecting nodes can be problematic. So far best method I’ve found is select both sides and then alt+J
Nodes cannot connect more than two lines. A three or four way intersection will not work.
