Just curious why I might have got this line during this burn? This is my first attempt at engraving. Not sure if it is software or hardware. Thanks
in my mind, there’s about a 90% chance it’s hardware…
check your Y-axis for a small bit of debris (on or under) the belt causing it to leap-frog ahead like that.
Gently move the head in the Y direction by hand and see if you can feel where it builds tension and releases it.
Hopefully it already fell out but it could still be hiding in the belt trough.
Thank you John! I appreciate the advice!
