Lines between objects and $32=1
So I have a problem which many users have - lines between shapes. If I put $32=1 then the laser is not switching on at all during burning(but Fire button is working), when I set $32=0 the laser is switching on during burning but there are lines… So what is the solution?
Many thanks!
I found why my laser is not ON when burning, I need to set Constant power is 1… but still strange. Also I found that if power is less than 10% Fire button, the light is not showing up.
Can you please give us more information about what type of machine you are using, software version, etc?..
A screenshot of the problem also helps.
If I understand correctly, at this point all I can indicate is follow these instructions:
What are your $30 and $31 set at?
$30=1000 (rpm max)
$31=0 (rpm min)
Currently I don’t have problems with the lines between shapes, but if I use Constant power off, then laser not firing. Also if I put < 10% frie button also not switching on the laser. So I need to put power > 10% and set “Constant power” ON, then it fires…
