Lines on top are thinner when I cut
Why are the top lines thinner than the other lines? There is noting different in the settings. Any idea?
Anyone? It’s not in the settings but somehow the upper lines get less power compared by the rest…
One possibility. Are side and bottom lines getting multiple cut passes from stacked images or duplicated lines?
Nope, the boxes are all the same, all 1 pass. Even with circles I have the same issue, the top half is a thinner line than the bottom half. Everything is cut out in one pass…
I tried the same cut on a different piece of wood with 2 passes, the same result, the top line is cut less deep than the side or bottom line…
