LM3. Not homing or moving after using YRC. Gantry won't move at all while laser is on
After using the YRC for quite a while, I went back to trying to use it as normal. Reverted settings by importing my settings that I saved before changing them for YRC use. Getting Alarm 9 and the motors sound like they are engaged but not running if that makes sense. I have the switch flipped back to Y motor and rotary turned off in settings. Jogging does not work either. Checked belts and they are tight and clean. Here is GRBL output with startup and error:
Waiting for connection…
ok
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[MODEL:Ortur Laser Master 3]
[OLF:210]
[OLH:OLM_ESP_PRO_V2.4B]
[OLM:GENERAL]
[DATE:20230223]
[SN:7410D2AFAE45AB59FD2993E5E71E0E85]
[VER:1.1f.20220325:]
[OPT:VNZHTS+,63,32767,3,0]
Target buffer size found
[NEWOPT:ENUMS,RT+,HOME,NOPROBE,TC,SED,UD,CLU,WIFI,FTP,TMC=7,SD,ITG,GT,YRR]
[FIRMWARE:grblHAL]
[NVS STORAGE:*FLASH]
[DRIVER:ESP32-S2]
[DRIVER VERSION:220327]
[DRIVER OPTIONS:GIT-NOTFOUND]
[BOARD:Ortur Laser Master 3]
[TYPE:OLM3]
[CLUSTER:16]
Cluster size found
[WIFI MAC:84:F7:03:E6:BC:80]
[IP:192.168.5.1]
[PLUGIN:Power Detecter v1.0]
[PLUGIN:Power Control v1.0]
[PLUGIN:gyroscope sensor v1.0]
[PLUGIN:Trinamic v0.09]
[PLUGIN:SDCARD v1.05]
[PLUGIN:ITG STREAM v1.00]
[PLUGIN:ESP32 WebUI v0.03]
[PLUGIN:GADGET v1.00]
[PLUGIN:YRR v1.00]
ok
Homing
<Home|MPos:116.088,298.400,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:23869,142|A:SFM>
[GC:G0 G54 G17 G20 G90 G94 G49 G98 G50 M5 M9 T0 F2999 S5.]
[MSG:25:Info: USB SERIAL STREAM CONNECTED]
Ortur Laser Master 3 Ready!
OLF:210.
OLH:OLM_ESP_PRO_V2.4B.
OLM:GENERAL.
GrblHAL 1.1f [‘$’ or ‘$HELP’ for help]
<Home|MPos:0.000,0.000,0.000|Bf:63,32767|FS:4242,0|CL:0,0|PS:2,0|VA:23977,67|Ov:100,100,100|A:SFM>
<Home|MPos:-149.200,-149.200,0.000|Bf:63,32767|FS:4242,0|CL:0,0|PS:2,0>
<Home|MPos:-299.125,-299.125,0.000|Bf:63,32767|FS:4242,0|CL:0,0|PS:2,0>
<Home|MPos:-449.050,-449.050,0.000|Bf:63,32767|FS:4242,0|CL:0,0|PS:2,0>
<Home|MPos:-598.987,-598.987,0.000|Bf:63,32767|FS:4242,0|CL:0,0|PS:2,0>
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
ok
OLF:210.
OLM:GENERAL.
[MSG:‘$H’|‘$X’ to unlock]
[MSG:3:Warning: Caution: Unlocked]
ok
<Idle|MPos:-645.000,-645.000,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:23865,140|Ov:100,100,100|A:SFM>
ok
[GC:G0 G54 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F0 S0.]
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G59.1:0.000,0.000,0.000]
[G59.2:0.000,0.000,0.000]
[G59.3:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[HOME:0.000,0.000,0.000:0]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
Hi Tim,
Goes without saying - you have reversed the switch to Ymotor on the back correct?
Type in console $RST=*
And follow the motor cables to the motherboard to be sure the Y cable did not slip out.
Alternatively, just to confirm there are signals coming off the Y cable - switch to YRR mode. Use YRR cable and plug from YRR port to X Motor. Try homing. The X should move instead of Y
