Lo x7 dsp (awc 708c)
Quick question. I started lasering something I noticed that dimensions in LB do not translate to the controller/machine. I tried doing 100x100 mm perfect square and output was 97x97 mm.
How would I adjust this?
Thank you
For the moment, you’d need to use LaserCad for this, in the system config settings. I’m working on adding machine settings for AWC to LightBurn, so it will be available in the next release or two.
Options -> System Options -> Manufacturer Parameters, then click “Read”. The highlighted values are what you’d adjust:
You can click the little […] buttons beside the values to have it compute the adjustment from a measured value. You tell it that you wanted 100mm but got 97mm and it will adjust accordingly.
Thank Oz! I believe this did the trick.
:slight_smile:
