I’ve written a script to use UDP commands (which are a great feature!) to load cut sequences from Python and execute them. I’m using the .hpgl format as it’s the most barebones ASCII format I saw, but I’m open to changing that. I cannot get lightburn to import the .hpgl files without centering them. Via the UI this can be done by holding shift during the import. Is there any equivalent for UDP commands? Or a way to disable the image shifting for all imports?
Thanks!
