I was not able to find a real solution. Basically, if I use the ‘reset’ button on the controller in between jobs, it makes things perfect cut after cut. Keep in mind, the ‘reset’ button is not the same as resetting the controller - that button just moves the laser head back to the starting corner, essentially guaranteeing that the position of your upcoming cuts is relative to the correct home position. By turning off your controller and restarting, you’re basically doing the same thing…but the ‘reset’ button is easier.
Probably better for the electronics…
In my life, most hardware failures occur during ‘power up’.
