My longer ray5 is confused (or I am) the furthest it will travel in y axis is 365mm. The dimensions of the work are are 375x375 in lightburn and real life. Anything between 365 and 375 triggers soft limit warning on the longer digital display and this gcode error in lightburn, "
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 0:"
How do I get back the 10 extra mm or do I have to surrender to a smaller work area?
Thanks Gil. I changed gcode 131 to 375 from 365 and that fixed it…my $132=200. The laser uses the whole area now though. Should I still change 132 from 200 to 375 for some other reason? Thanks again
