I am new to this so please bear with me on my use of terminology. I am unsure how to change my workspace in Lightburn so that it matches my physical workspace. The attached screenshot is the current setting and the bottom left corner is actually physically in the very center of my board I want to burn the image on. I cannot figure out how to change that. Would someone please help out a newbie here?
Welcome @jonhorton
You can change it in Device Settings:
Also I invite you to have a look at the LightBurn Docs:
Thanks for those links. They are full of info. Not sure if it is clear, but I have the device settings at 400 and 400 for width and height, per the manual. However, the laser head does not use all that space. It starts from the center of that space. That is what is confusing me. It is as though I trained it / configured it to only use the top right quadrant. This picture shows the position of the laser which is in the center of the board although Lightburn has it in the bottom left corner. It seems like the laser is is not physically where is should be. Maybe this is a question for Longer?
I have manually moved it to where I wanted it to start, Chose Start From Current Position, ran the Frame and it worked on the physical board. It still does not match what is on the screen in the Lightburn software. When I follow the laser position in Lightburn, it is outside of the workspace in Lightburn but perfectly centered physically on the board. I just dont understand ![]()
To make this happen, you need to use Absolute Coords in the Laser window. Then you can imagine everything you draw is hovering above the laser workspace. Where you draw is where the laser will go.
That Error 5 suggests why the “start in the center” thingie is happening. If the machine does not Home, then the Origin will be wherever you power it up instead of the Home switch corner. You must have limit switches for the Home operation to work. I am guessing the Longer Ray 5 has them.
In the Console window, enter $$. Then look for the $22 parameter. It should read $22=1, but if it is $22=0, enter $22=1 in the Console window. Then click on the Home button in the Laser window.
Let us know how this turns out. ![]()
And welcome to the Forum!!!
I mostly use Current Position too,
Eg. With the laser at the middle:
You have to pay attention to the size of the shapes your sending to the laser. lets say
If the shapes have a size of 300x300 mm and the origin dot is at the middle it works fine.
But if the origin dot is at lower left
the laser may hit the rails or gives an error.Does the laser have limit switches and is capable of doing a homing cycle? Such laser NEVER know where the head is, they don’t have any positioning sensors. They only know how much they have travelled from the starting point. Homing moves the head to a defined position from where travel can be calculated. If you do not have homing functionality, you need to place the head in the starting position before turning it on.
You guys rock! All of the above advice and tips are gold. I feel sooooo much better knwoing I am not crazy.
Thanks again!!!
