LONGER RAY5 5W: solid black engraves, but gray and fine details disappear
Hello, I need help diagnosing inconsistent engraving on a LONGER RAY5, before changing more settings or assuming a hardware fault.
Equipment:
  • RAY5 5 W diode, 400 x 400 mm
  • MKS DLC32 V2.1
  • Firmware reports GRBL 1.1h.20250721 / Software V2.2.12
  • LightBurn Pro Trial 2.2.00 on Windows, USB COM8
Symptoms:
Solid black areas engrave very dark, but dithered mid-gray areas can disappear almost completely. Fine contours also come out broken or missing. Jobs finish by themselves normally; they are not manually stopped. Similar results occur over USB and when running exported G-code directly from microSD.
Controlled square test: 2000 mm/min, 40% maximum power, 0.1 mm line interval, one pass. The exported M4 code uses S400 for a solid 10 mm black area, and short alternating S400/S0 runs (roughly 0.1–0.3 mm) for the dithered area. The solid area burns dark but the dithered area is largely absent. A corresponding M3 test did not visibly solve this.
LONGER support suggested Grayscale with Negative enabled. We tried a three-block black/white/mid-gray image as well. The exported code contains continuous 10 mm stretches at S400 and S200, with S0 for white. We still did not obtain a useful intermediate tone. Tests were made on both a pale smooth wooden piece and a rough brown fiberboard; the material species are not confirmed.
Relevant settings:
$30=1000, $31=0, $32=1; LightBurn S-value max=1000.
$100=$101=80; $110=$111=6000; $120=$121=500.
$20=0, $21=0, $22=0.
Focus has been set with the supplied gauge against the module reference surface, not the red protective shield. The carriage/module has no noticeable looseness. Photos of the lens were not clear enough to establish its condition, so that has not been ruled out.
Could you suggest a diagnostic sequence to distinguish image processing, power modulation/firmware behavior, optics and material response? In particular, what would explain a solid S400 area marking strongly while short S400 pulses and/or a continuous S200 area fail to produce usable marks? I would appreciate advice on which exported commands/settings to check, rather than simply increasing power.
I will attach the test image, project/G-code and photographs of the results where the forum allows it. Thank you.
PROYECTO CUADRADOS.lbrn2 (3,9 KB)
PROYECTO CUADRADOS.gc (115,3 KB)
ESCALA GRISES INVERTIDA.gc (5,5 KB)
Hi
Can you post a screenshot of your cut settings.
I assume you are running this test in Greyscale…So could it be that you are Not using enough Minimum power and also using too much Maximum Power.
You may be below the threshold to show results for 18%grey.
Are you trying to burn holes through the material in the image.
Hi Pete, thank you. No, I am not trying to burn holes: the aim is a shallow, detailed engraving. Some black patches are clearly over-burned while lighter details are missing.
There have been several different tests, so I should distinguish them rather than describe everything as grayscale:
  1. Stucki square test: 2000 mm/min, 40% maximum power, 0.10 mm interval, one pass, M4. The solid black block marks strongly, but the dithered block is largely absent. The project and G-code are attached to my first post. An M3 version was also run from microSD, without an obvious recovery of the missing detail.
  2. Grayscale + Negative, suggested by LONGER support: the attached ESCALA GRISES INVERTIDA.gc contains continuous 10 mm sections at S400 and S200 (and S0 for white), F2000. It did not produce a useful mid-tone on either material. The photograph in my first post shows those results. This is separate from the Stucki test.
  3. Black/white line-thickness tests in Threshold mode: 2000 mm/min and 40%, with one and then two passes. More passes darkened marks but did not reliably restore the interrupted thin lines.
  4. More recent Threshold trials include 1000 mm/min at 25% and 900 mm/min at 35%, one pass, 0.10 mm interval, bidirectional scanning on, overscan 2.5%, Negative off and Constant Power off. The newer result has continuous long marks, although that does not yet establish that small dither dots will reproduce well. I cannot reliably assign every mark on the reused board to one setting, so I do not want to present it as a controlled comparison.
I am attaching three settings photographs, labeled by their filenames/timestamps:
  • 2026-10-29 09.57.26: Grayscale + Negative selected, 6000 mm/min, max 20%, displayed min 20%, 0.10 mm interval, one pass. This is an earlier settings screenshot, NOT the F2000/S400/S200 exported test above.
  • 2026-10-29 13.13.07: Threshold, 900 mm/min, max 35%, displayed minimum 20% greyed out.
  • 2026-10-29 13.13.25: Threshold, 1000 mm/min, max 25%, displayed minimum 20% greyed out.
The greyed-out minimum shown in Threshold mode should not be confused with an active grayscale minimum. I understand your point about finding the material’s usable power range; we have not yet calibrated that range successfully.
The tests have been made on pale smooth wood and rough brown fiberboard, with focus set using the supplied gauge and no noticeable carriage/module play. Jobs finish normally, and the issue is seen both over USB and from microSD. $30 and LightBurn S-value max are both 1000; $31=0 and $32=1.
One additional workflow issue was identified: a supplied bird G-code was imported and regenerated in LightBurn, producing thousands of separate G0/G1 strokes. That is not the same as running the untouched factory raster G-code, so I am not treating that bird result as proof that the original factory file fails.
Given the attached square project and these distinctions, which specific test/settings would you recommend to establish a usable range without over-burning the black areas? Thank you for your help.
Your welcome Raul.
I would recommend that you carry out a basic Lightburn materials test. Any dither mode will suffice as it seems to be the dither pattern you are having problems with. The material test will objectively show you how the material reacts to your laser module across a variety of speed and power settings.
You can run the Material test with any of the image or dither modes.
For any given material the laser will mark or not mark given sufficient power and an image colour value that meets the threshold. The only other factor is speed which must allow time for the marking to occur.
Constant power should be off for all these tests, Negative is of no consequence as you are applying a positive test…and not burning on dark material.
You will see the material test is (Power-%) and (Speed-mm/min) rated so I suggest you use those terms…not S-values.
If you can post screenshot using the computers own software tools like ‘Screen-snip’ or other it will provide a full detail picture that is easier to read (I am using my small-ish phone screen at the moment).
