Longer RAY5 Connection to MAC issue
I have bought a Longer RAY5 and Lightburn but I cant get it to connect to my Imac.
When i first connected the cable I got a message saying that the port was being used or open. i moved the usb cable and i worked for a little bit. I could move the print head.
Then it stopped again and no matter what i do I cant get it to connect.
here is a short video of the issue
https://somup.com/c3lebUwY3L
here are the error messages
Waiting for connection…
Port failed to open - already in use?
��@�J�����!I+k’�a�}RR�R ��AJun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DOUT, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5856
entry 0x400806a8
[MSG:X Axis Standard Stepper Step:I2SO(1) Dir:I2SO(2) Disable:I2SO(0) Limits(-400.000,0.000)]
[MSG:Y Axis Standard Stepper Step:I2SO(5) Dir:I2SO(6) Disable:I2SO(0) Limits(-400.000,0.000)]
[MSG:Laser spindle on Pin:GPIO(22), Enbl:None, Freq:1000Hz, Res:16bits Laser mode:On]
Grbl 1.1 [‘$’ for help]
Your Grbl may not support Variable Power mode (M4)
If your laser does not turn off between cuts,
switch to the GRBL-M3 device
[MSG:Connected with 192.168.0.119]
[MSG:Start mDNS with hostname:http://grblesp.local/]
[MSG:HTTP Started]
[MSG:TELNET Started 8080]
ok
[VER:1.1.2022010301:]
[OPT:PHSW]
[MSG:Using machine:LGT RAY]
[MSG:Mode=STA:SSID=TP-Link_F620:Status=Connected:IP=192.168.0.119:MAC=E8-9F-6D-AA-30-F8]
ok
This makes it look like you are connected.
A few things to look out for:
  1. Make sure no other programs are potentially opening the port. Any communications program, CNC program, microcontroller programming software, etc. are potential candidates
  2. If you haven’t, try rebooting the computer.
  3. Make sure the proper port is selected in the Port field in between “Devices” button and laser device name in Laesr window.
  4. Try forcing reconnect by right-clicking “Devices” button in Laser window
