I’ve searched high and wide for a step by step guide to get lightburn to recognise my wireless IP camera. I’ve tried using both OBS project and splitcam, which the camera works fine via RTSP connection and I can view the cameras perfectly and even using them in 3rd party apps such as zoom.
I understand that lightburn due to the way the program was written requires the camera to appear as UVC connection, but making that happen is tricky! I need to connect wirelessly as I use my laser outside as I don’t have the capacity to run a fume extraction set up, so I watch through a sliding glass door (with eye protection), but due to the property being a rental, I can’t run any cabling through the walls/doors/windows.
I’m using a mac (OS Ventura 13.0.1) and lightburn (1.3.01).
Hi there,
I have the same issue and did a lot of research on this. At the OBS forum (Thread.
I found some interesting things and it looks like that this is an issue with code signing. The solutions (
codesign --remove-signature /Applications/…) are for meeting apps like Zoom and Teams. For me it looks like that this can be adopted for Lightburn but this is above my knowledge. I started Lightburn via terminal (/Applications/LightBurn.app/Contents/MacOS/LightBurn) an got the following in the output: 2022-12-29 14:51:53.683 LightBurn[24142:517251] Error loading /Library/CoreMediaIO/Plug-Ins/DAL/obs-mac-virtualcam.plugin/Contents/MacOS/obs-mac-virtualcam: dlopen(/Library/CoreMediaIO/Plug-Ins/DAL/obs-mac-virtualcam.plugin/Contents/MacOS/obs-mac-virtualcam, 0x0106): tried: '/Library/CoreMediaIO/Plug-Ins/DAL/obs-mac-virtualcam.plugin/Contents/MacOS/obs-mac-virtualcam' (code signature in <AA80FC44-EBA9-3AB0-9BBC-3AFA9E5894A6> '/Library/CoreMediaIO/Plug-Ins/DAL/obs-mac-virtualcam.plugin/Contents/MacOS/obs-mac-virtualcam' not valid for use in process: mapping process and mapped file (non-platform) have different Team IDs)
I can use the virtual camera in OBS but not outside it. My versions are OBS 28.1.2, Mac OS 12.6.2, Lightburn 1.3.01.
