Im running lightburn into xpro v5 grbl on a plasma cnc cutter. I understand Torch height control cant work with this setup unless its a stand alone unit, So id like to run torch touchoff/ probe setup. Im lead to believe theres a space for g code to be entered so the torch can drive down/touch and push a micro switch which is wired to the xpro v5 probe input. then go up to pierce height and fire, then drop to cut height whilst cutting… how do i do this? what commands do i enter? can i just load it and it stays in the code for all future commands ? Or do i need to unload the gcode, make adjustments to it, then load it back each time hopefully with any info would be great, Thanks Peter
Go to Edit > Device Settings
Then the GCode
tab:
Anything you enter there will get output to the start or end of the job. As for what you enter, I can’t tell you - it’s up to what your machine needs. But yes, it will be output forever unless you change it.
