Loses position engraving
hi. I have a new S30 Pro Max and sometimes don’t engrave well. I think it is maybe because of a tight X axis belt because I Sense a little resistance moving the module with my hand in some points or maybe a firmware problem because sometimes the machine don’t power off in the button only when I took the power cable off .
Any tips? I use lightburn
Uploading: 8E5970A5-4022-4C4E-A459-3197A0E53032.jpeg…
Uploading: 9E1A9ECB-D8D5-4535-9A6B-C852D2E4BBC5.jpeg…
Here is a guide on how to check the complete mechanics: Guide to mechanical adjustments and maintenance Go through and check if everything runs smoothly.
Next, what settings did you use?
