Losing cut layer along the bottom after saving project
Hello, I’m running Lightburn 1.1.03
After my last update whenever I resave a project while working on it I lose my cut layers along the bottom. I’ve tried the screen minimizing and maximizing trick, no luck. My only workaround has been to close out of Lightburn and then reopen project and cut layer is there but then disappears after the first save again.
I think I understand what you’re saying. I’m brand new to lightburn, but I’ll try to help. In the top menu bar, there is a + and - button. Hit the minus button to shrink the grid, and your project will be exposed. Hope this helps.
Negative… thats the maximize… minimize trick I mentioned. Can anybody else tell me whats happening? Thanks
Under the window tab, Top selection “reset to default layout” then save.
Thank you I’ll try that.
