So I installed a Cohesion board Display and Camera on a k40. I already had the Light burn software installed for low wattage laser diode and wanted to use it with the k40 but after install the K40 was skipping steps during travel. I had to go into the firmware and reduce the max speed from 24000 to 2400 and it seemed to fix the issue. Now the problem is I can seem to cut anything, I have the laser at 80% and traveling at 8mms and with 5 passes I cant get through card stock. The watt meter is showing about 30 watts at 80%. I feel like the conversion might of been a mistake, I was cutting 1/4 ply with less power than I am trying to cut card stock. The laser is better aligned than it ever has been. I dont know what to do, am hoping it is a simple software change.
