Lumitool F20 with new motherboard compatibility with Light Burn
The indication from Lumitool is that they are now compatible with LB as long as we have sent our unit back for the hardware upgrade. Is it true? I have had this boat anchor for over a year now, but I am unable to use it as the software provided is less than capable.
Hello Bill,
Welcome to the forum!
We have heard of this upgrade from another user’s request asking for a driver but so far, we can only guess, which controller Lumitool is installing.
Please let us know if you have any further information.
They are asking us to use BSL&L as the laser during setup.
I will attempt to set it up tonight after work and I will let you all know how it goes. Fingers Crossed!
That’s good to hear. You will need to install their custom driver in order to connect.
Make sure to use “Create Manually” and select BSLFiber from the list instead of “Find My Laser”.
In the next step, you’ll need to import the config file, which you should have received.
This documentation might come in handy: Add a Galvo Laser - LightBurn Documentation
Good Luck!
@wcbeme I’m curious to know if you managed to connect your Lumitool?
