Did something change with LB 2.1 that no longer allows the units for the display dimensions to be in inches while the machine setting is set to mm/sec? It used to be that you could select inches in the top of the main screen and the speed and power in the layer setting would stay mm/s to match the machine set up. Now if I change the main screen to inches it changes my layer settings and it if I go into the device setting and change it to mm/sec it changes my display settings. I am not too happy with this as I work/draw in inches but run/program my machine in mm/sec. Am I missing something? If there somewhere else that needs to be changed to allow me to draw in inches without having layer setting change from mm/sec to inches/sec?
A bit different behavior read the Doc:
Got it.. Thank you very much. This update has been more of a learning experience than any of the previous updates.
