Getting the error “there was a problem sending data to the laser. the machine may be busy or paused.”
I’m using laser master 2, 15W.
please help resolving this issue.
A post was split to a new topic: Error when overwriting a file on controller
This usually means you aren’t actually connected yet. Have you chosen a COM port? Do you see output in the console window before trying to run a job?https://lightburnsoftware.github.io/NewDocs/ConnectingToTheLaser.html
There are bug(s) in the Ortur firmware that can cause this problem, see this thread:
