I set my machine origin to lower left(like the youtube video says) and my image came out mirrored.
I played around with the other 3 corners and the image is still always mirrored once i burn it, but not on my computer screen.
So i set it back to lower left but now when i try to use the cursor to set my laser location, it goes in the opposite direction. For instance,(origin lower left) if i click the lower left on my computer to move the laser, it moves to the UPPER left…and vice versa.
You do not say what controller you have. Where does the laser go when you first turn it on? Since it looks like you have a DSP controller, you would set your ‘Machine Origin’ to match that location.
This will flip things on-screen so you can flip those using the icons found near the center-top of the LightBurn UI, or you can select and press H or V to flip horizontally or vertically.
