I’m trying to get my Z axis adjusted so that I can lower my bed a little more to accommodate a rotary. I know to go to Machine settings>Vendor settings> Z axis> Max travel, and adjust as needed. My question is, after adjusting, do I need to click “OK” or “WRITE” ? Thanks for anyones help in advance.
The changes in ‘Machine Settings’ are help internally, you must ‘write’ them back to the controller for the changes to be reflected on the machine.
If you modify something there and click ‘ok’ without writing it back to the controller, it advises you that values were changed and gives you options.
You can also save the ‘new’ configuration…
