Machine settings do not load information
I’ve just installed a Neje Master 2, followed all the orientations, but when i try to load machine settings, it do not work. Even when i try to load from the “NejeMaster2MachineSettings.lbset”. The configuration do not apear on the window, that shows “no controller settings returned”, even when i try to load from file. Can pleasse ane one tells me what i’m doing wrong?
For starters, are you actually connected to the controller, and is it running GRBL firmware?
My problem seems to be solved. I runned the LaserGLBR and after that, the Lightburn recognized the machine settings.
Now i’ll test the burning configurations.
I apreciate the immediate response from you. Thanks.
