Machine stopped - OLM 3
I have an ortur laser master 3 and while engraving a large piece it stops half way through, I read the messages and typed reset and the next message popped up and I have no idea what to do.
Uploading
IMG_0810
: IMG_0810.jpeg…
scroll up in the console the error that originally caused the error is above
Also is machine homing correctly?
can you show a bigger windows
laughs at your machine profile name! :smiley:
lets see if we can help to change that
Machine is homing perfectly fine. I’ll show you what I’m working on to hopefully make finding
a solution easier. It will frame the project perfectly fine, but when it gets to the farthest point it stops.
I believe your problem might be Over-Scan
You are getting a tad close to the edge and your Over-Scan might be hitting the soft limit
2 options
a) disable soft limit temporarily
b) lower the % of overscan or completely disable it
I would reduce power to 1% and try either
1% won’t engrave anything but will test all motions
How would I do that?
Regarding Overscan
As per machine settings
Edit → machine settings
Click the “Soft limits” toggle so it goes red
then write
Test either option with 1% power dry run though to be sure it works not to waste any material
is a mechanical - path issue so laser dont need to engrave to test
Changing the soft limits fixed the problem, thank you so much
put them back after, they are a nice safety net 90% of the times
