Machine stops working suddenly
Good evening, my machine works good for a months but now when I try to print a photograph it starts working but after a few minutes it stops. But when I use machine for engraving or for cutting something it works well. I updated the firmware of the machine and the lightburn software but the problem still exist. I don’t know if it is a problem of the machine or a lightburn’s problem.
Try changing from bufferred mode to synchronous mode in the bottom right of the device settings window.
Otherwise perhaps provide some info about the equipment and what is displayed in the console window.
I changed the mode but it keeps stop. In the window appears that:
Error 1:G-coded words consist of a letter and a value. The letter was not found. On or near line 4594.
Error 20: Unsupported or invalid g-code command found in block. On or near line 0:
Job halted
