I am using CorelDraw X8. I can do the Macro install and it works fine. BUT when I turn off CorelDraw and later come back the LB Macro does not work. It is still in the tool tray. BUY I have to reinstall it each time. I have saved setup as default. That does not help.
If I wannnna use LB with CD X8 I must reload it each time. WHY? Thanks forward for any help.
not sure, but you can try, after install macros on corel, go to tools menu and click “set settings as default”
Thanks for the help, I will give it a try today.
Merry Christmas
Macro works fine Thanks again for the help
