Make laser work from top to bottom
Can anyone tell me how to make the laser work from top to bottom instead of bottom. Got a project that screwed up and a little bit of top part has to be engraved again but dont want the whole piece done again.
Hey,
Use the ‘Start here’ function from the Preview mode.
Hope this helps
Mine is not high lighted to use
Please explain more
Select the ‘image’ of what you are lasering. Take care not to move anything
hit play and when it gets to the point where you want to start from hit play again to pause it then select start here…which will be greyed out until you play the preview
Thanks so much
