I am trying to make the letters outline with 8.0pt line. I can do it in Corel but when importing into LB, it goes back to a hairline. What setting am I missing in LB to make this happen? Would prefer to do this in LB instead of Corel. Thanks, Jim
Lightburn is for a tool path. If you want it filled or thicker, you need to convert it to a path and apply offset to allow an area to fill, making the line thicker…
Maybe someone else has a trick for this…
Thank you. I knew it had to be easy.
