Is there any way that the camera overlay can be made just as clear as the live view? I think that would help out with some of the alignment issues we are having
Nevermind, i started going through the settings and figured it out . Now my alignment is almost spot on.
You’re using this with a rotary? Camera use requires the ability to position both axis of the laser with absolute positioning. Connecting the rotary means the Y axis can no longer be moved, so it doesn’t work well for rotary use.
Ok, i don’t understand what you just said. So you are saying that the camera does not work to use it with a rotary? I have been using it fine. Not sure i understood you correctly or if you got confused.
