Mansfield roller is starting and stoping incorrectly
Mf 2028 80 watt Omtech have a Mansfield rotary
Rolls forward about 30mm and starts laser correctly lasers wrapped image but stops at the origin spot, also starting spot. Wheel diameter of 24mm. Repetes at 2050 on steps per rotation. DM545A dip switches correct. User origin.
Hello Walt, Wish I had an answer for you. Have to ask if you figured out what the issue was. I have the same machine and was looking at buying the Rotary from Mansfield. Take care & best of luck.
Milton
