I search for an opration manual for a CRS Laser CRS-355-15 UV Laser source.
The Material available on their Website or from the Machine Manufacturer is very confusing.
On one point the datasheet states 60-150 kHz frequency range, but in the same sheet it says maximum power @50 kHz and Pulse length < 12ns at 50 kHz.
The usable or allowed puls lengths are not even mentioned.
Can anzone poride me with the correct values or even better the operation manual?
I don’t want to destroy my machine by running it out of specs.
Any help greatly appreciated!
Cheers,
Christian
p.s. Of couse i already contacted CRS Laser directly (3 weeks ago), but they seem to have no interest in answering me.
Not sure you can, it will likely ignore what it cannot process.
Keep it clean and you should be okay.
As for those settings, the Universal Rule for any type of laser is, “Test, test, and then test again. Every situation is different, meaning the laser, materials, and the environment. Settings you hear about are only to be used as guidelines to get you started. It is up to you to adjust those settings to get what you want, or expect.”
I have a 60W machine, it’s specifications tell me the maximum power out is at 45kHz. It’s frequency range is 1 to 4mHz. Not surprising.
@MikeyH is likely correct, you probably can’t tell it to damage itself. I only know I can’t afford a uv machine and only a little bit, but they seem to be known as low/no heat lasers. I understand it disassembles glass molecules. But that’s about all I know about them.
Thanks for both your answers, but i think you both got me completelz wrong.
@MikeyH
I didn’t mean the working/eg Material Parameters.
I meant the basic machine parameters to utilize the laser.
If frequency or Puls range are exceeded zou can easillz damage a fiber or (in my case) UV laser.
@jkwilborn
Might be you have a 60W Machine, but if i get your parameters right, i is most likely a 60w JPT MOPA laser. I have such machine myself.
The machine in question though is a UV laser. (NOT a fiber/MOPA laser)
So zou think 60-150kHz range with 50 kHz makes sense? I highly doubt it.
For the “little brother” the 255-5 (5W) They give a frequency range of 10 to 150kHz with max at 30 kHz. That is what i can confirm, having such machine myself. Also there is a pulse length range of 1 to 20ns. Which is competelz omitted for the 355-15.
Yes, I do have a fiber MOPA, guess I missed that when I wrote it.
I know my manual for my MOPA says the most power is at 45kHz, even though I can get up to 4,000kHz frequency. So I can believe maximum power could occur at a lower frequency.
I was attempting to let you know I don’t own a UV machine, so I was just speculating.
This is what I was understanding. I do not have a UV either, so I was answering as an Electronics Technician.
However, the only way to get accurate answers is to contact the manufacturer, ESPECIALLY if you are capable of harming the machine by inputting out-of-tolerance parameters. Depending on word-of-mouth answers is risky at best.
I suspect what @jkwilborn was trying to suggest is why even consider operating out of the specified range? I expect you would normally operate within a fairly narrow band of adjustments. I know this is going to sound trite, but stay away from the limits if you are worried that you could harm the machine.
Well, that’s the whole point of my post.
The published settings i found are so confusing, that i fear i can’t trust them at all.
Especially because no pulse width range is given for the 15W Model.
An, as i already mentioned, i still have no answer from CRS Laser by now.
Pulse width is specified at a laboratory test condition, and indicates their minimum pulse duration under ideal conditions. It is a specification, not a setting.
