boa tarde,
precisava de uma peque ajuda
tenho um projeto com varias camadas mas esta a gravar a linha de ligação entre as camadas
Good afternoon,
needed a little help
I have a project with several layers but it is recording the connecting line between the layers
Go to Edit->Machine Settings and check for the value of $32. If it is 0 (off) currently switch to 1 (on).
boa tarde,
fiz a configuração conforme explicou, mas assim não faz o corte por completo.
obrigado
Good afternoon,
I did the configuration as explained, but it does not cut completely.
thanks
JohnJohn
(John Johnson)
4
The next step is often speed reduction.
Please share a picture of the incompleteness you mention. I would like to understand.
system
(system)
Closed
5
