Marked square is not square and not to the size drawn
New Boss Laser FM Station:
We drew a 200mm x 200mm square, marked it then checked the dimensions. The image shows what we measured. The numbers in red are as measured, in blue are what they should be. Those on an angle are the diagonals.
How do we correct this?
Thank you for your help.
In the LB machine settings menu there is a section for calibrating X and Y
Given that it’s a fiber laser and assuming you’ve loaded the proper machine / lens configuration, perhaps:
