Hi,
I am using Marlin 2.0.9.1 on a Ramps 1.4 board to control my Chinese co2 laser.
I have noticed in some conditions, at the end of the cut, the laser does NOT turn off. As you can imagine, this is dangerous. When this happens, even if I issue a M5 command via the console, the laser does not turn off. There may be a bug in the in-line-power code that is causing this. I have noticed that this seems to happen when my cuts start with a warning that the cut would be out of bounds. I’d get this because I cannot home Y when I have a rotary tool attached, so I just fake it with G92 commands.
The workaround I have in place is by appending some gcode at the end of the cut. This is done by going to the device setup, and adding G1 X1 I S0 to set the power via inline move command to 0.
Has anyone else experience this? Laser on/off control works fine in all other operations, just doesn’t respect M5 at the end.
