I am considering purchasing this software, but it doesn’t seem to something for my Marlin based with PWM laser. It can’t seem to control output level of the laser, only on or off.
I’d like to be able to set the levels (currently using the M106 and M107 gcode commands, and having a threshold for min, to still be able to use M106 with a low level that won’t etch, to avoid turning the laser all of the way off). (the delay of on/off with M107 makes the edges inconsistent for raster like etching)
I’d also like to be able to use the levels in order to etch images, which seems like it would provide better grayscale like levels to make better image etching.
From the old documentation below, it seems like the min power is not supported on GCode controllers (like Marlin).
So my questions are really:
Are levels already or soon to be supported with the M106 Gcode commands?
Will a low threshold be configurable to allow setting of a low threshold that would not turn off the laser, but would not etch? (from the old documentation that feature is on Ruida that a threshold will be used, if below that threshold/min value)
ender 3, creality 4.2.7 board, with th3d unified2 marlin firmware, Sovol 500mW laser via fan pins (with M106,M107 control)
LightBurn already sends power adjustment commands through M106 Sxxx (xxx being the power level). It is possible to get updates to the Marlin firmware that don’t have the fan ramping / delay in them, and those are much better for laser use.
At least now I can see that the gcode is giving a variety of levels for the M106 Sxxx (power level).
Could there be a setting for Lightburn with Marlin, that still lets you set the min power when not using Greyscale too? That also may help me and others to overcome the fan delay by setting the min to something that still has the laser on, but not burning the material.
I will also look into more Marlin updates for the removing the fan ramping, but would you have suggestions for where to start?
Even if I did force Marlin to never go below a certain power output level, there’s no guarantee that would fix the fan ramping issue. I suspect they always ramp the power change, not just from when it’s off to when you turn it on, but also between level changes, in which case your suggestion wouldn’t improve anything. The correct fix is to use a version of Marlin with the fan ramping disabled at compile time. Unfortunately I think that’s the only way to change that - a compile time switch.
