I am running into a new issue that is driving me crazy. My speed and power settings revert to the wrong settings although I have the correct units selected in the Lightburn settings. I have a Thunder Laser Bolt and previously was runnning an Xtool D1 so I have both lasers loaded into Lightburn and the units differ for both (Thunder - mm/sec, XTool - in/min). Sometimes to reconnect to my laser having to turn it on the right click on device does not connect and I have to swap the laser and swap back for it to connect which is not a big deal. But this sometimes reverts my units from Thunder to the units of Xtool even though it still says mm/s they are way out of wack. They are completely wrong in materials library and layers. Today after this happened, I changed the units then swapped them back and updated speed/power in layer and when I sent the job to my Thunder it was operating at a much slower speed than was set. Ideas?
Do you have ‘Load default layer settings on new or restart’ enabled in the Editor Settings tab of the Settings window?
That setting is not enabled. I apologize for my tardiness. I was out of town.
