I have been struggling with using the material library because of the naming and structure. This morning after many past fails, I finally figured out where I was going wrong, The use of Title, however, still bothers me. I finally get that it is to be used for “operation,” but why not use Operation instead of Title. I am sure there is a valid reason, but the nomenclature throughout the material library kept confusing me. Of course, I am not as mentailly sharp as I used to be, but… Would changing Title to Operation be a reasonable change and maybe even helpful for others with agiing brains such as mine? Thanks for considering.
I believe everything depends on the interpretation given and especially on how it is executed.
(Then there is also the issue of translation from the original language to the end user’s language, which may not be entirely compatible.)
I have my material library organized as follows:
Material type > Operation type (engraving or cutting) where “no thickness” means engraving or carve, and where thickness exists, in addition to separating by thickness, I also define the color (for materials of varying colors, even if the same thickness, the settings may be different).
As I update the material list, I save it in date format in order to know which is the most recent library.
