My Material Library is in metric, and I would like it in ASA. I have the ASA .clb file from my other computer, but when I try to load it in Lightburn, the program reverts to the metric .clb instead of the ASA file I asked to load. I even tried renaming the metric .clb file, but that didn’t change anything. Lightburn still loads the metric .clb file, not the ASA .clb file. Is there a setting somewhere that makes the .clb go to metric?
I believe these are all XML type files. You can open them or look at them with a text editor. Virtually every field has a pretty good description.
Only guessing, but I suspect these are only dealt with in metric… Lightburn uses metric internally and all of these Chinese hobby machines work internally in metric, as does my Ruida.
This is something that only the Lightburn people may know. I have never needed it and I don’t remember any discussions about it.
In LB you can’t enter fractions, you must enter Imperial numbers such as 0.1875" as opposed to 3/16"
ASA (now ANSI) isn’t about mathematical formulas, it’s about measuring and standardizing everything from film speed (ISO), how many frames a second a film camera runs, the width of railroad tracks, the amount of electrical power that goes into a residential home, why a 2x4 doesn’t measure 2" x 4" and so on.
As you said, if you wanted to know the metric equivalent to 5", then yes you would use 25.4 (5 x 25.4 = 30.4).
Not true. Play before you say. Kind of like try before you buy.
Enter 3/16” while you have in or mm selected.
To enter 3-3/16”, you must convert to an Improper Fraction: 51/16”
Or just enter it as 5” in the box displaying a Metric value. As @ednisley says, not all numeric fields work, but definately the ones used to design your paths.
Well Shut my mouth, of the 16 different graphic design software that I have loaded on my system and used for decades this is a first time I’ve learned of this.
Went into the archives as it has been a while… got it. The memo:
Equations:
This one is a pet project of mine: LightBurn’s X & Y position, width, height, scale, and interval entry boxes now support expressions and units. What does this mean for you?
If you type 1/2in, and you’re in mm mode, it’ll turn into 12.7. If you’re in inch mode and type 1/2in, it’ll become 0.5. You can use ft, cm, in, or mm, along with normal math symbols and parenthesis (*/-+). You can combine them, so entering (1/2in + 3mm) * 2.5 + 1ft is valid. You can type 1/300in in the interval box to have it convert “300 lines per inch” into an interval for you. This should make working in mixed units easier.
Over the next release or two I’ll be replacing other number boxes with the new equation entry box, but it’ll take a bit of time.
In that case to Ligtburn understand:
If in Inch you have to input 3"+3/16" or 3+3/16 or 3"+3/16 or 3+3/16" (=51/16≈80.963)
If in mm you have to input 3"+3/16" (≈80.963≈51/16)
