I download the lightburn software but its missing the material library. I did reset and reinstall nothing. If someone can point me to the correct direction to download.
thx C
Lightburn does not come with a preloaded material library, it has the function to save your own library from your test results.
Thanks for that, I have Atomstack P1 laser is anyway I can move those preset into ,Lightburn ?
Its lot to manually :
Not that I’m aware of. If you just do it as you go you will eventually have everything saved and it won’t be overwhelming.
