Material library out of wack 2.1.04
Monport Reno 65 Pro / Win11, I opened a new project and selected my cut from my Library, and it looked off, so i opened another project done on the same machine and this is what i found.
A lot of stuff is off what happened… Yes i upgraded to 2.1.04 today, so I am starting to think hmm.
Very accurate hmm thinking! Lightburn changed how we manage control (laser) and design (grid) settings. They can now be linked with a switch. Design and run in same units = switch on. Design in inches and run in mm (or the other way around) = switch off. Turn the switch off and recheck all your settings.
i see this, the only issue with it is , the two screen shots i showed are for the same laser on the same pc, just a second window opened.
Where did you grab the layer in the Cut editor cause it isn’t in the Cut/Layers window?
Also pay attention that 509.55 in/m = too fast 15000 mm/m .
You know that does not make sense, right? Did you open a second instance of MillMage?
none are cuts, this is purely engrave
This appears to just be a switch between in/min and mm/sec units?
i would agree with you but when i open the library up on 2 projects on the same computer, same laser… one would think the setting will be the same… so I am getting 2 different readouts in the same library for the same material. hmm
It entirely depends on what you are currently viewing the workspace in, because you have Design and Machine units linked. If one window is set to MM, and one window is set to IN, you will see two different numbers there. They are effectively the same, just displayed in different units based on what your workspace’s current setting is. Turn linked units off to prevent this.
These two machines are set to different control units, but the actual speed is the same.
250 mm/sec is the same speed as 590.55 inches/minute
250mm / 25.4 = 9.8425 inches/sec x 60 seconds = 590.55 inches/minute
The link Colin posted above will guide you to un-linking control and design units if that’s how you work.
