Is there a particular reason why the Y Center and X Center values are not saved with a preset? When I’m testing, I prefer to move across a piece of material as I’m trying different values. Retaining the values would be a help.
They don’t save on mine either.
I follow what you mean…
It would be very nice if it even remembered settings from a previous use in that instance of Lightburn.
If you’re in there testing, and close it, you have to enter all of the changed values again… it’s irritating… I shouldn’t have to save it and reload it every time I use the function.
Maybe @JohnJohn could advise…
Yes its odd that position is the only setting not saved, I have also found it odd that the default location is dead centre of the work area, I would imagine most people start by doing their test in a corner so the home location would make a good start point. there is enough data to calculate where the centre needs to be if working from Home.
Guess I’m not most people
Depends on the machine. It seems to me I do it on my Ruida/grbl using user origin.
On the fiber, there is no user origin, so I use the center work area …
Can’t say I’ve ever had an problem using it the way it is, at least from this standpoint.
I was also doing this a bit before the materials test was available… along with being old, so I do forget some things
Of all the things I forget, why can’t I forget how old I am?
Oh I was thinking along the lines of if its in the corner this will leave a lager workable area to use when testing complete.
What were we talking about ?
Please post this idea on our Feature Suggestions site.
Have a look for your idea, and if someone else already posted it there please upvote it.
