Material test location
Is there a way to relocate where the material test is located for cutting?
It depends on which Start From Setting you are using. If you use Absolute Coordinates you can adjust the X cent er and Y Center in the dialog box. If you’re using current position it will run from where your laser is sitting. If you’re using User Origin it will start from the origin you have set.
