Material test parameter setting lightburn 1.7.08
i had recently done a material test using my aurora uv fiber laser where i had set the min and max range for a couple of parameters - i think it was frequency and speed.
anyhow i had done the material test and looked at the results - pick a setting which looked good - but when i tried to put the parameters in the test table into settings to do a burn, lightburn would not let me set the frequency to the one in the material test result.
after a little looking around what was going on - i saw that the value was outside the range of the laser.
so in the material test i inadvertently put some values outside the capabilities of my laser.
so what are the values in the material test represent then if they are not limited to the parameters of the laser in use - what did it do for the out of range values??.
my laser is limited to 150KHz but in the material test as a max value i put in 200KHz
and one of the test boxes which looked good was at 180KHz which my laser could not do.
