Material test partial faulure
Im using @ longer ray5 10watt. Laser waz working fine. Havent used it because i baught an extension kit so had to build new enclosure. Ive taken laser from 400mm x 400mm to 850 x 850mm. Today first its been used since upgrade. I followed directions to adjust settings for upgrade. Ran a material test. The text came out as expected, but it didnt engrave any of the engrave boxes. Module moves way past the area it showed in framing. It was barely fire laser as well as it was moving way to much on xaxis, would on run 3 or 4 lines of yaxis. But nothing engraved9
Post an image so people can see what you see.
